Valve ticking?..
Discussion in 'Engine/Drivetrain' started by DumpsterToy, Oct 14, 2013.
  1. DumpsterToy
    DumpsterToy Member
    Rancho cucamonga
    93 single cab
    Ive adjusted the valves twice now according to the haynes manual. Anybody have any advice on the noise? Should you be able to hear a slight tick or should it be silent. Also i have a brand new head installed
  2. goldstandard
    goldstandard Member
    Erwin, NC
    94 extended cab
    From what I've heard it's normal to have a little tick. I've had mine adjusted by a mechanic, and it still has it. It runs fine, so I'll have to learn to live with it.
  3. DumpsterToy
    DumpsterToy Member
    Rancho cucamonga
    93 single cab
    Haha thanks bud. Ive heard it too down the line, it doesnt bother me i just wanted to make sure it was safe and not a mistake on my part. Thanks again
  4. The Jewish Guy
    The Jewish Guy Veteran
    I had the same problem and then my mechanic suggested i use Premium 93 Octane gas and that got ride of the ticking noise.. for a few cents more at the pump it was worth it plus my Hilux runs better than before.. my MPG increased..
    Use PREMIUM GAS.... Sunoco is like 93.5 Octane
  5. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    Is that a new rocker arm assembly also.The lobes get worn .But yes a slight ticking is very common for our motors.
  6. yota89
    yota89 Enthusiast
    guam
    89 single cab
    yup very common for our motor i have changed the valve adjusting screws on mine and its still
    the same i was told by my mechanic to use full synthetic oil havent got around to doing so because i just did a connecting rod bearing job with new oil and filter regular 10-30 oil
  7. CrazyCody93
    CrazyCody93 Enthusiast
    Gresham OR
    84 Sr5 Xtra cab
    Also, if you use an oil additive such as the lucas or hyperlube additive it took my valve ticking completely away
  8. Lotoy
    Lotoy Enthusiast
    knoxville tn
    92 std cab
    A little valve tick is normal! If u didn't have it the valves would to tight!
  9. efiliatedmini92
    efiliatedmini92 Newbie
    chino, ca
    92xcab longbed dlx
    make sure to not overtighten your valve cover bolts too, since the valve cover is bolted to the rocker assembly, if you overtighten it that can affect the valve adjustment.
  10. DumpsterToy
    DumpsterToy Member
    Rancho cucamonga
    93 single cab
    Thank you all very much. Since its so common in sure you answered a lot of new toyota owners concern. Lol
  11. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    my valves sound like 2 skeltons shankin' on a tin roof!
  12. Litneon
    Cocoa, FL
    94 xtra cab
    I'm pretty sure that if you use the rubbers that seal the valve cover bolts, there is no way to deform the rocker assembly. The cover itself deforms and causes leaks when they get over tightened. There are 10 large head bolts (or studs in my case) holding the assembly firmly in place. The cam exerts way more force on that assembly than you ever could with those four nuts. Just sayin'...
  13. 9-zero-9
    9-zero-9 Newbie
    bullhead city, az
    90 xcab
    Yeah had same ticking sound.. Had valves adjusted.. Got quiter then a few months later noise started again and was louder..pulled valve cover to find 2 lobes on cam not getting oil and wore down cam lobes 1/4 inch.. Damn it..lol
