valve adjustment
Discussion in 'Engine/Drivetrain' started by estgang1991, Apr 15, 2013.
  1. estgang1991
    estgang1991 Enthusiast
    oklahoma city, oklahoma
    '89 hilux
    i have an exhuast valve leaking a little, you can hear it when it's running and the exhaust is sucking backa little. what are the facorty specs for adjusting the exhaust valves, i'm less worried about the intake valves than the exhaust. any info will help. suggest threads or give me links please?!?:confused:
  2. CrazyCody93
    CrazyCody93 Enthusiast
    Gresham OR
    84 Sr5 Xtra cab
    the numbers are .008 and .012, larger one is the exhaust. Just make sure you adjust them when its hot
  3. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    ^ sorry your suppost to do it cold hot would make it looser once it cools down
  4. estgang1991
    '89 hilux
    i actually found a guide on how to do it online. you do it cold, turn the engine when #1 is a TDC(timing mark on 0) and adjust the INT and Exhuast on the #1, INT on #2 and Exhaust on #3 then turn the engine 360 degrees, or to where #4 cylinder is at TDC(same as before) and adjust the intake and exhaust on #4, Exhaust on #2, and intake on #3. the numbers are right, 0.008 on the intake side and 0.012 on the exhaust. the way i always remember it, is that the intake valves are the closest to the intake and "carb" and the exhaust are the ones closer to the exhaust manifold. and it's supposed ^ lol
  5. estgang1991
    '89 hilux
    make sure the timing marks are on 0 both times!!!!!!!!!!
  6. NashMan
    NashMan Toyotaholic
    94 2wd
    as long as it is on the bottom of the lobe you will be fine it is the same lift for about some thing like 15 degrees of the cam just thinking off the top of my head mabye more with out looking at a cam card or factory profile
  7. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    This would not cause a valve leak unless your valve lash was way off.
  8. NashMan
    NashMan Toyotaholic
    94 2wd
    it most likely burnt any who
  9. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    I'd check your valve springs may have a broken spring .. Been down that road took out my head gasket
  10. estgang1991
    '89 hilux
    http://www.toyotaminis.com/forum/newreply.php?do=newreply&p=173797
    i'm sure it's not a burn valve... well almost... i'm do what i can to it tomorrow to see what i can do to it
    http://www.toyotaminis.com/forum/newreply.php?do=newreply&p=173811my instructor at school is who brought it to my attention, he said he heard what he said he thought was a tap in it from about 15' away from it and came over and listened to it and he said he'd almost guarantee that it was just a valve leaking. not burn^^
  11. silkeepjs
    silkeepjs Enthusiast
    Richfield, Ut
    94 Single cab (Sold), 81 SR5
  12. silkeepjs
    Richfield, Ut
    tapping could also be broken timing chain guide...
  13. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    These engines are gonna tap...should sound like a lil sewing machine. Wait til the engines cold and set them at .007 intake and .011, exhaust.
  14. estgang1991
    '89 hilux
    naw bro, engine was rebuilt not long ago. new timing chain and all, i saw the receipts. the exhaust is sucking back a little when it's running, and that's why dude said it was a valve
  15. silkeepjs
    Richfield, Ut
    when i first got my 94 the tining chain guide was broken. I replaced the chain and guide with the kit sold at autozone...sure enough, 20k later it's broken again. i know it was caused from me beating on her, and i've learned to take it easy. But the plastic guides are terrible anyways. currently saving some $$ to buy the double row kit from 22reperformance.com.
  16. NashMan
    NashMan Toyotaholic
    94 2wd
    once a valve leaks it will burn/leav resadew and if left long eghough the sealing will never be the same again
    in less the vavle is re lapped with paste, I have dry lapped them before it helps but if to far gone it is a waste of time
