Uhhhh Help?
Discussion in 'Suspension/Chassis' started by strebdogman, Apr 20, 2010.
  1. strebdogman
    strebdogman Member
    maryland
    94 std
    i cant decide on my sexuality:shrug: (says the gf lol as she reads over my shoulder) I am a bit confused how do you z your frame and why before i make a big oops? I have bags and everything i need to drop it with the exception of brackets and a clue i have been reading up on it. Dont want to mess up the other build threads with my idiocies. Im going to can do for the brackets. Unless someone can change my mind. Also a really dumb question how do you post pics????? help me Obi-Wan Kenobi your my only hope!
  2. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    You Z the frame so you will lay out flat. You cut both sides before the firewall an let the rest of the frame drop an weld it up an add gussets so it looks like a Z then you drop the front frame horns the same as the Z so your sheetmetal still lines up. Cando makes good quality stuff I just ordered control arms for my truck from them haven't got them in yet but they have great customer service
  3. strebdogman
    strebdogman Member
    maryland
    94 std
    Ok thanks that helps a bit is there a thread on here or if someone has pics that would be awsome.
  4. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
