U-joint ?
Discussion in 'Engine/Drivetrain' started by josealex1636, Sep 14, 2012.
  1. josealex1636
    josealex1636 Veteran
    Ontario,CA
    83 Toyota Pickup
    Does anyone know what u-joints are good? I installed the autozone ones and the u-joint on the trans side popped out well the bearing piece of sh*t autozone u-joints.
  2. Litneon
    Cocoa, FL
    94 xtra cab
    What do you mean popped out? Picture?
  3. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    You might have a damaged flange the u-joint goes into. I've seen them when they go out of round and the drive line has to be sent to a shop to be repaired.
  4. josealex1636
    Ontario,CA
    83 Toyota Pickup
    Well the bearing popped out and I pull the other sides bearing out but ill just do that at my school on moday.
  5. TDS909
    TDS909 Veteran
    ONTARIO
    1992 st cab
    Autozone one's are ****! I can hook you up with toyota one's if you want?:D
  6. dillinja666
    See how shiny the inside of the yoke is, you need to take it down and have then put a new yoke on it, the caps are loose inside the yoke and falling off/out. Yoke is warped on the drive line part. You can see it in the second pic.
