In the quest to owning an earlier truck, I'm going to be lifting my 92 back to stock height before I try to sell it. My questions to you guys is... what year U-Bolts are interchangeable with 89-95 trucks? The last time I was at the Pick-a-Part, they had a few pre 89 trucks and a single V6 95 4-runner. Will any of these work? Thanks in advance.
4runners are coil in the rear unless its the older style. Even then it wont fit. Any mini truck 2wd axle over leaf will work. As long as the u bolts are U shapped not sqaure shaped.
*should* use new ones. I'd reuse them if they're just a few years old and look decent but I would NOT reuse ones from a junkyard truck. They aren't that expensive, be safe.
I was able to pick up a set this morning.The ones I pulled from the Truck look beefier than the ones currently on my truck. If they look like they wont hold, I'll get new ones. Thanks again guys
