Turn Signal Cancel
Discussion in 'Interior/Electronics' started by SterStruck, Jun 27, 2013.
  1. SterStruck
    SterStruck Newbie
    Hawaii
    Hi. I just bought a 93 pickup. Whenever I take a turn, the blinkers stay on until I turn it off manually. I need to know if these trucks came stock with the turn signal cancel. Ive removed the steering wheel and couldnt find any canceling cam. Anybody know?
  2. IronNam
    Should be standard, the stalk on yours must be worn.
    Does it happen like that in both directions?
  3. SterStruck
    SterStruck Newbie
    Hawaii
    Thanks for the reply! It doesnt work at all in either direction.
  4. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    sounds like the signal cam is either broken or could be just stuck with years of lint dust and grease.... pull the steering wheel and take a look at the little cam..
  5. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Is the steering wheel stock or aftermarket?
  6. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Clean all the contacts and the switch guts. Wheel should have a post or two to cancel them. Post some pics.
  7. SterStruck
    SterStruck Newbie
    Hawaii
    I know this is a sh@tty pic, But u can see a gap behind the steering wheel. They are no posts anywhere. I do know that the previous owner had an aftermarket steering wheel on it. Does it look like anything is missing? I can take a pic with the steering wheel removed if needed. Thanks guys.
  8. White Trash
    Eastern WA
    If you take off the steering wheel you'll see 2 small holes in the backside of it. The white spring loaded ring that contacts the steering wheel is supposed to have 2 matching pegs that fit in there. That's what is supposed to cancel the blinkers as it turns.
  9. SterStruck
    SterStruck Newbie
    Hawaii
    Thanks for the info. I didnt see any pegs yesterday. Ill remove the steering wheel and check again. Ill also take a better pic with the steering wheel removed.
  10. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    If the PO had an aftermarket wheel, the cancel cam probably didn't fit under the hub adapter and he tossed it (or he just lost it due to stupid). I have cheap grant wheels on everything and the auto-cancel still works so either he had something weird or a case of the stupid.
  11. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Same here I have a grant on my truck and was able to use the blinker off cam ..the guy probably rushed the job and tossed the the idea of wanting auto off blinkers ..a junk yard migh have the stuff your looking for
