Truck now dies when brakes applied.
Discussion in 'Engine/Drivetrain' started by Kahuna, Jan 9, 2012.
  1. Kahuna
    Kahuna Enthusiast
    AZ
    94 single cab
    OMG...what is going on!?!?!?
    So last night my (94, 22r-e, 5 speed, single cab, 4x2) just started to do this last night. Truck will intermittently die when i apply brakes no matter what the speed!
    BUT!!! Only when going forward....Reverse...nada.
    So, far we checked for vaccuum leaks...None to be found. (Googled the problem.....most results stated it was a brake vaccuum issue)
    Anyone have any ideas or solutions to this???
  2. Kahuna
    Kahuna Enthusiast
    AZ
    94 single cab
    Comforting to know...I'm the only one who has had this problem.
  3. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    I had the problem also but i was carbed and didnt ever figure it out lol.
  4. krazedprof
    krazedprof Addict
    iowa
    1991 reg cab & 1994 4runner
    could be the power booster leaking internally i had a similar problem and replaced the booster and didn't have the problem anymore also replaced the master cylinder while i was at it just to be safe.
  5. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    Does it die every time or just once in a while? When its cold or after its been running awhile?
  6. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    I had a similar problem, brakes started to lock up while driving and ended up killing the motor..I had to bleed them to even move the truck..replaced the MC and all was well, yours sounds weird though, there is no electrical connection except the sensor on the MC cap
  7. Kahuna
    Kahuna Enthusiast
    AZ
    94 single cab
    I would say 7 out of 10 times i can get it to die.....at any speed. But only while going forward. never has it or can i get it to die while in reverse.
    Cold/hot/warm engine makes no difference.
  8. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    Are you loosing any fluid in your master? Are you burning smoke? I had a leak from my master into my booster and it sent the brake fluid thru my carbs and burned it out thru the exhaust. Freaked me out. Check the check valve in the line coming from the booster. I think your booster has gone out
  9. Kahuna
    Kahuna Enthusiast
    AZ
    94 single cab
    Neg on the brake fluid level dropping....It's exactly the same as the day i picked it up 2 months ago.
  10. Kahuna
    Kahuna Enthusiast
    AZ
    94 single cab
    Found something new about this problem....rolling to a stop sign, push the clutch....put in neutral....apply brake, the truck tries to die.
    Now i try rowing through the gears...5, 4, 3, 2, 1, while cruising to a stop, trying to keep the rpms up a bit. stay in 1st until i almost get the truck to jerk. Push in clutch apply brake...all is fine.
  11. dillinja666
    ya im gonna say booster as well
  12. Kahuna
    Kahuna Enthusiast
    AZ
    94 single cab
    Jeez....It keeps geting better. Now the truck will lose power while driving. Not all the time...but it still happens. Not touching the clutch or brake...cruising at 65mph....truck cuts off. I just jump it back on with the clutch. Man O man....am I have a ball with this or what!!!!!
  13. garagedoorman
    garagedoorman Addict
    north georgia
  14. Kahuna
    Kahuna Enthusiast
    AZ
    94 single cab
    garagedoorman.......cuts off while throttled. cut off 3 times this morning. (was in the fast lane at 75mph) I Pushin the clutch dropped into four gear let the clutch out and it jumped back to life. everytime it has cut off I can hear the fuel pump relay make a pop sound. Ill check out that link!!!
  15. Kahuna
    Kahuna Enthusiast
    AZ
    94 single cab
    Hey Garagedoorman...If you are ever in AZ...Please hit me up!!! Cause I owe you a beer or two!!! The link you provided had the answer to my problem!!!!!! The problem was a loose ECU fuse in the fuse block. Everything is running so perfect now!!!!!!
  16. garagedoorman
    north georgia
    :waytogo:Good for you! Just lucky. I'll take you up on your offer someday
