My truck tilts like crazy!!! The front is even. Lowered with 4 inch blocks and cranked torsions. It's about 2 inches higher on the passenger side in the rear. What the hell is wrong it looks horrible
You sure the front is lowered evenly? Are both rear shocks the same length? The front is probably uneven
On level ground jack the front tires off the ground by then center of the cross member under their engine and see if it levels out. Rinse and repeat on their rear to see if thr nose is even.
Well readjust the front. Thats more than likely what the problem is. If you think about it having the front left lower its going to make the right rear higher
Could've? "Hey guys my truck is sitting crooked and it pulls hard to the right, what could be the problem? " [insert several intelligent replis here] "Oh yea the passenger front tire is flat but I don't know what is causing it's lean!"
I wasn't literally asking why it tilts. I meant what could have happened that made only the rear passenger side so much lower
