truck cuts out but dosent die
Discussion in 'Engine/Drivetrain' started by 95toy, Dec 26, 2009.
  1. 95toy
    95toy Newbie
    hey guys im new to the sight. im having trouble with my 95 pickup. 150,000 and this is the first trouble its give me.22re. it seems to cut out when i hold the skinny pedal steady going down the road. im going to start ohming everything tomorrow but is there anything specific i should check. any help is appreciated.
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    how well does it accelerate? is there any hesitation? how long has it been since the fuel filter was changed?
  3. Nook
    Nook Addict
    oregon
    How long since the fuel filter was changed? might be a good starting place if its been a while.
  4. Nook
    Nook Addict
    oregon
    ya beat me to the punch SD :)
  5. 73TRD
    73TRD Veteran
    Redding, CA
    84 sr5 standard cab short bed, 73 hilux short bed
    fuel filter is definitely the best place to start. also your pump. check the ceramics on your spark plugs to see if any of them have broken loose. i had one break at around 5k on my new motor and it had a problem similar to yours
  6. 95toy
    95toy Newbie
    the filter is new. i am gonna go with the pump next. expensive but ill do it i think that is where im at
  7. 22r
    22r Veteran
    Maui
    try pull out one of the spark plugs and see if there ok (gap is nice , electrode still there, and the color, it should be like a brownish ashy color) if not change the plugs, cap, and rotor.
  8. DannyEarl
    DannyEarl Newbie
    95 pickup 2wd 2.4L 5spd
    Don't just replace the fuel pump! At least not without some evidence that it's bad. I don't think there are too many problems with fuel pumps on toyotas at all. let alone these bullet proof trucks. Start with something simple. Spray water on the plug wires/distributor see if that makes it run bad. Clean the throttle body. Maybe check the O2 sensor voltage...
  9. 95toy
    95toy Newbie
    ill give it a shot dannyearl. i was going to have the fuel pressure checked. ill play with it and see what i can do
