Trouble after removing charcoal can
Discussion in 'Engine/Drivetrain' started by ToxicToyz, Feb 11, 2013.
  1. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    So I decided to clean up my engine bay by removing the charcoal canister and the VSV valve/solenoid. I didn't notice and problems at first, but when I drove it accelerating was the same but when I hold a steady throttle in 4th and 5th, it will sputter a little and sometimes it feels like the trucks going to die and picks back up again.
    Need a 22r expert, doesn't feel safe at all to be driving.
  2. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    has nothing it do with cansiter
    in less you mixed you vacume lines up or took off the wrong vs and took off the one that control the fuel reg
    even my 22re get grumpy some time then clear's up I neck named it (IT'S 22RE THING)
    but easy fix is to pull the efi fuse and then plug it in so the ecu can re learn
    then see if it comes back
    good luck
  3. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    My motor is carb(22r), and I removed everything on the passengerside of the bay except the battery, fuse box, amd starter relay. And I plugged the vacume lines.
  4. NashMan
    NashMan Toyotaholic
    94 2wd
    ya i look into vacume lines may have some thing rooted wrong
  5. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    agreed. double check your vac routing. i removed mine a few months ago and have no issues.
  6. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    Well cant find anything wrong with the lines. All the lines that were plugged into all that evap stuff got capped after removal
  7. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Did u put a vacuum cap on your fuel tank vent to the charcoal can hose or leave it vented to the atmosphere.
    Witch switches did u remove both vac switches 1-2 and the vacuum advance switch located next to them ?
  8. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    The tank vent from the canister is vent to the atmosphere and both switches were removed
  9. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Do you still have vacuum advance solinoid its bolted to the same bracket round metal thing one vacuum line hooked to it
  10. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    took off everything, do I have to put these back now??
  11. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Ha no it's to ugly to put back I tossed mine to if u have a factory carb in good running order there very sensitive to changes that black solenoid to the bottom left of picture looks like the vacuum advance solenoid ..u may check your timing and bump it up a hair may resolve your hiccup at cruising speed that solenoid is connected to one of the two tubes running of the dizzy if I remember correctly via the metal vacuum lines
  12. 22r
    22r Veteran
    Maui
    you can also try spray starting fluid to see if any plugs are leaking. also change your fuel filter. do you hhave the stock aisin carb?
  13. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    Yeah stock carb
  14. 22r
    22r Veteran
    Maui
    so this only happens at cruisng speed or does it cut out past a certaim rpm with load?
    jdd likes this.
  15. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    Mostly around 2000 to 2200 rpms steady speed, when accelerating no problems
  16. 22r
    22r Veteran
    Maui
    WOT no problems either?
  17. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    WOT there no problems, only between 2000 and 2500 rpms when holding steady throttle or decelerating part throttle does it start to sputter.
  18. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Plug your vacuum line on the inside port on the dizzy and see if it does it . The vacuum line not the nipple on the dizzy
  19. 22r
    22r Veteran
    Maui
    try un plugging both vac lines to the dizzy and capm. then run the truck see if get problems. The other line is for emission purposes, which can be plugged.
  20. Toy88yota
    Toy88yota Member
    88 2wd
    When I desmogged my 22r I had to hook that upper valve thing back up to get it to run good / not backfire. My repair manual called it a vacuum switch, may not be your issue but worth a shot.
    It's the middle left one in the picture. Atleast thats what mine looks like.
    The 88 vacuum diagram shows where it should be hooked up.
    22R, 22RE, 22RTE Vacuum Diagrams - Pirate4x4.Com : 4x4 and Off-Road Forum
