Transmission Swap
Discussion in 'Engine/Drivetrain' started by ShortyzKustomz, Aug 10, 2011.
  1. ShortyzKustomz
    ShortyzKustomz Enthusiast
    Central Va.
    94 Single Cab
    Aiight guys, Im starting to get parts together for my motor swap. I am curious about transmission differences. My truck is a 94 22re 2wd. I want to swap in a R150 trans from same generation V6 2wd truck. Are the trans mount locations, shifter location and drive shaft length the same?
  2. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    i dont think you can put a rXXX trans series to a 22r/e engine. I would get a w58, shifts nicer then the R trans, lighter and cheaper. Plus i know they bolt up :)
  3. ShortyzKustomz
    Central Va.
    94 Single Cab
    Yeah Im getting rid of the 22re, Therefore my reasoning for the new trans, I was wondering if everything else stays the same or if I need a new driveshaft, crossmember etc. Long story short, Im swapping in a GM 3800 Series II motor in my truck, The R150 trans with a AX15 input shaft and a 95-99 Dakota 2.5 bellhousing "should" bolt up fine. I know 4wd drive guys have done it, Im just going on a hope that the 2wd R series trannys are the same as far as how the bellhousing bolts up and input shaft etc. I havent seen much for 2wd swaps. Just trying to see if its better to do it this way. Or if I have to redo everything, Just stick with the GM T-5 thats with the motor and make a tranny mount, get a driveshaft made etc.
  4. IronNam
    R154 would do the job... i believe
  5. ShortyzKustomz
    Central Va.
    94 Single Cab
    Does that share the same size input shaft as the AX-15 trans? Im assuming so but the one instructions I found was using a R150. I know you gotta swap input shafts cause the AX-15 in a hair longer. And what about tranny mount, driveshaft and, shifter location?
  6. ShortyzKustomz
    Central Va.
    94 Single Cab
    Plus a r154 would be alot more $$ and harder to come by with the Supra guys all over them
    Edit: Actually found some cheap locally, It asks me ABS or non ABS though?
    Also it says the R154 Input shaft is longer, therefor would I even need to swap input shafts?
  7. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Use t5 stuff out of a camaro. If you can swap in a 90* v6, you can make a trans mount and have a driveshaft made.
    Making it way more complicated than it has to be.
    Youll need a driveshaft and a mount for either transmission. Its going to be MUCH cheaper going with a t5.
  8. ShortyzKustomz
    Central Va.
    94 Single Cab
    Thats why I was asking, trying to save as much $$ as possible and didnt know if the tranny mount and driveshaft was the same. If I use the T5 I def will have to redo my tranny tunnel (again) and crossmember (again) lol. I was just hoping there was a simpler solution, If the wiring mounts and exhaust werent enough. Driveshafts arent cheap
  9. geonbugman
    geonbugman Member
    Columbus
    93 Pick-up
    It's possible to fab your own drive shaft. Just remember to keep the phazing correct. I have spliced a couple of shats my self. (best one yet, Suzuki Sami slid into GM for a 321 Odd fire/th250 into my Sammy.) Had to make shimms to fit between both shafts and did plug welds to grab the cut end of the sammy shaft inside the GM shaft, then I did a careful weld around the open end of the GM shaft to seal it all up. Afterwords I used 4 hose clamps to balance the unit for testing. Drive shaft shop only charged $20 to balance profesionaly for me.
  10. dillinja666
    my r154 looks longer then my w58, i can go look tomorrow after noon and let ya know. I have 2 r154s ( i plan on blowing both of them up too )
  11. ShortyzKustomz
    Central Va.
    94 Single Cab
    Yeah lemme know, I plan on yankin the motor for a 5 speed car, So if I have to snatch tranny too and fab tranny mount etc I will.
    Heres one with the T5
    http://www.toyotaminis.com/forum/build-up-project-threads-23/84-engine-swap-gm-series-ii-3-8-makeover-10227/
    And heres a 4wd using all Toyota drivetrain which is what got me thinking, Later on in the post and another guy both said using the Dakota 2.5 bellhousing eliminates the need for the adapter plate
    3800 II in 90' Toy 4x4 P.u. w/Toy running gear - Pirate4x4.Com Bulletin Board
  12. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    -Rxxx transmission will need a different driveshaft than the Wxx, at least in cressidas/supras (w58/r154) it does.
    -mount should be the same.
    -shifter location is adjustable just like the Wxx boxes.
    It's a trade off as far as difficulty and money...camaro T-5 and 3800 will bolt together like it's meant to be, clutches and other parts can be had for it easily. sure you'll have to do the trans mount and shifter hole but it's trans/bellhousing headache that can be trouble getting replacement parts for down the line that you won't have to deal with. doing the toyota gearbox you'll have to use a mish-mash of parts that *should* work and if it does, will be harder to get replacement parts if it does break because you have to find bits from 3 different cars to make it fit. it'd be one thing if it were a UZ swap and they didn't make a manual bellhousing for it... why work harder than you have to.
