transmission swap questions
Discussion in 'Engine/Drivetrain' started by thompson13, May 6, 2014.
  1. thompson13
    thompson13 Newbie
    Hey all. The 4spd in my 76 longbed is toast and I found a deal on a newer(89-95) 5spd. Before I get too far into this I would like to know if this is feasible without having to get a new driveshaft and all that. And if its not which transmission would be the easiest to put in. Thanks in advanced!
  2. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    the transmission + bellhousing length of the old tranny should be different than that of the new tranny + bellhousing. You will need to have the length of your driveshaft adjusted. Many shops should be able to do this for around $100.
    Also its highly unlikely the old bellhousing will work with the new transmission, so make sure you get that, too.
    You should also find out if the new transmission is for cable driven speedo (like you have)
  3. Cade01
    Cade01 Veteran
    Eugene, OR
    1973 Toyota Hilux
    Doesn't the '76 have a W40 in it, and the 89-95 should be a W50? Wouldn't that be a pretty straight forward swap?
  4. thompson13
    thompson13 Newbie
    I wanna say its an l40 or something along those lines but I'm not positive
  5. Tuhd The Troll
    Houston, TX
    1982 SR5
    The W50 stopped being the toyota pickup 5-speed somewhere around '83, and was replaced by the W55 (and then the W57, 59, etc)
    The bellhousing for the w40/50 won't work with the W55/56/57/58/59 transmissions, as it is a different length. The bell for the W55+ is interchangable among the W55+ models, last I checked.
  6. Cade01
    Cade01 Veteran
    Eugene, OR
    1973 Toyota Hilux
    Ah, I see.
  7. EuroTrashh
    EuroTrashh Newbie
    what year are these model transmissions?
