Transmission id please.
Discussion in 'Engine/Drivetrain' started by opus, May 18, 2010.
  1. opus
    opus Newbie
    Greetings one and all,
    I really dont see any numbers that mean much to me. Can you give me a hint to what transmission this is?
  2. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    I got that trans,...........a four speed, right?
    B.Y.E. sold it to me, maybe it came out of his 82????
  3. opus
    opus Newbie
    No, I thought it was a 5 spd.
  4. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    4 speed = W42 (same one I sold to Raff) Yes, it came out of my '82...
    5-speed = W52 (steel center casing).
  5. Raffaelli
    Houston
    82 Longbed 2WD
    The original trans that came out of my 82 truck had a cast-in bellhousing and was all cast iron.
    It seriously almost killed me when I pulled i. :lol:
    W42- 98% sure thats the same sucker. What are you going to do/wondering with that trans Opus?
  6. opus
    opus Newbie
    I just bought an 84 2wd rig, missing the transmission. I need a 5 spd to stick in there. Local guy gave me this and told me to give it a try.
    That is a steel center casing with aluminum on either end....no?
  7. B.Y.E.
    B.Y.E. Toyotaholic
    1982 2wd Hilux
    I'm about 98% sure it's a 4 speed looking at the center and tail section. Doesn't look like it's holding a 5th set of gears by the looks of it...
    Try sticking the ****er in and shift thru the gears...
  8. opus
    opus Newbie
    OK, thanks, will do.
  9. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    or just mark the tail shaft and input shaft with a white pen, both at 12 oclock. Put it in 5th ( if it has one ) and spin the input one time and look at the marking on the tail shaft, it should be facing at 9 or 3 oclock depending on which way you spun the input ( meaning it didnt make one full revolution. ) If it goes past 12 in the direction you are spinning the input you are in 3rd noth 5th. good luck.
    cool thing is im working on figuring out if that bell housing fits the w58 body, if it does you saved yourself a PITA trying to find a bell housing to fit a w58 and can now easily swap the trans from a supra into that truck.
  10. dillinja666
    so a semi reliable source told me that the bell housing you have will indeed fit the w58 transmission, so go on craigslist and search for one. It will basically turn your truck into a light weight 22R or 20R supra..which sounds pretty fun.
  11. Raffaelli
    Houston
    82 Longbed 2WD
    Cast iron center....:lol:
    its a four speed. Its identical to mine. The price was right so just run it.
    And I have, and will continue to reccomend the w58 box (for a 5 speed).
  12. opus
    opus Newbie
    But it already is and was a 22R.
  13. opus
    opus Newbie
    Sorry to say but you were all wrong. It is a 5 spd and I cant say it was a lot of fun putting it in. Maybe I am just getting old.......
