Transmission Build.
Discussion in 'Engine/Drivetrain' started by divinemarquis, Jun 29, 2014.
  1. divinemarquis
    divinemarquis Newbie
    Heres a question, probably a stupid one: Is it possible to replace some of the gears in a transmission with aftermarket ones that are a little faster (as in higher geared). I have a 5 speed (Not original and not sure what the code for it is) in front of a 3.07 rear. I have an extra 5 speed just sitting there not doing anything. I was wondering if I could build that one to squeeze more mileage out of the truck and just swap the trannys when I was done building it. Stupid question, or no?
  2. Kev55
    Kev55 Enthusiast
    florida
    I'm not exactly sure what your purpose for trying this would be... I mean I'm sure it's 'possible' to swap a gear out. But if you want to make a faster truck, this would not be very effective at all..
    And if you're trying to get better mileage (to save money I assume) again this would not be practical and most likely cost a pretty penny..
  3. divinemarquis
    I wasnt trying to make the truck faster, it was with fuel economy in mind. Im just curious as to what my options are.
  4. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    A W58 is the only easy option you have to gain a higher 5th gear. I'm running a W58 in a truck that came stock with 3.07's. I swapped the 3.07's out for 4.10's prior to swapping the 4 speed for the W58 so I can't speak for the exact rpm range it would run in. I can say it's made the truck into a decent driver even with smallish 195/60/15's.
