Tranny wobble
Discussion in 'Engine/Drivetrain' started by Kev55, Oct 5, 2012.
  1. Kev55
    Kev55 Enthusiast
    florida
    There is a broken or worn seal or barring that is making my driveshaft wobble right at the tranny. I thought it was a bad uv-joint but when I went under there both joints were fine but on the end going into the tranny is a lot of play.
    I attached a picture to show exactly where I feel all the wiggle room.
    For the longest time I had been trying to figure out why I was getting such vibration driving.
    another thing, could I have caused this or is it a mix between being 170k old? Im really not abusive to my truck and take it easy on her. But Im constantly throwing it back and forth in Drive and Neutral. I dont do it hard, only to coast to red lights and things like that. Im just so used to driving stick, it doesn't make sense to me to remain engaged when im slowing down or standing still. :shrug:
    Like I said though, I dont drop it in "Drive" hard, but maybe this simple constant action is adding extra stress it wasn't designed for..
  2. R-Tan
    R-Tan Enthusiast
    Apple Valley, CA
    88 std cab
    Im not sure, someone who knows more than me will probably chime in, but i dont see any picture either.
  3. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Well at least u found that elusive problem I don't think it's your driving style it maybe the mileage but I still consider 170k low for these trucks you may have a bad output bearing causing some play in the driveshaft input shaft it's not to much of a hassle to get to it maybe stubborn coming out tho
    What trans do you have
  4. Lowtide671
    Lowtide671 Enthusiast
    88' single cab 2wd
    hmmmmm really sounds like just a bad tranny mount. when you inspected the Ujoints how did the spline look? were they very straight with minimal wear marks?? also if it was a bad output bearing I'm thinking you would hear ALOT of noise with the trans engaged. if you have one of those IR temp guns then you could probe that area and see very high temps if it were a bad bearing. based off your trouble description it sounds like a bad tranny mount, dose the motor shift a lot when you put it in drive?
  5. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    If you can get under the truck should be able to remove the rear counter bearing while the tail cone of the trans is still connected to the trans if not the tail cone can be removed and the then you can remove the counter bearing via a press out or a nice size screw driver ...give it plenty of wheel bearing grease upon reassembly ....
  6. Kev55
    Kev55 Enthusiast
    florida
    oh woops lol here now it's attached.
    I couldnt find an exact name for the trans. but it's a Rwd 1988 22RE
    Yeh I called a mechanic today he said its a bushing or something. Said the same thing, not hard to get to just have to get the old one out and a new one pressed in.
    I would rather do this myself but maaannn... I dont want to get stumped trying to get the old one out and forcing the new one in. Seams like such a simple thing to do. There's gotta be an advanced auto tool i can borrow to yank that bitch out.
  7. Kev55
    Kev55 Enthusiast
    florida
    Yeh it was broken, and shook BAD but I already replaced it. The issue is still there in the
    I think taking off the cone part was what my mechanic was talking about! He's a brazilian guy, sooooo tough to understand that dude lol but he's good. He meant I could do it myself and just bring the cone part to him and he'll press the new bushing inside! perfect!
    I dont get any other sign, like no scraping, loud noises or anything like that. I just get a lot of wobbling from the middle of my car.
  8. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    So you replaced it and still gettin a wobble ?
  9. Kev55
    Kev55 Enthusiast
    florida
    no I meant to reply to Lowtide, the tranny mount was bad but I had already replaced it. It still wobbles, It's very well the reason my old tranny mount broke in the first place.
