Tranny fluid drain/fill
Discussion in 'Engine/Drivetrain' started by GrantH, Jul 17, 2009.
  1. GrantH
    GrantH Addict
    Hattiesburg, MS
    Do you have to open it up from that big ol' plug on the very bottom or is there another that can drain? I'm not even sure if it has fluid as it was pulled and all for the stock floor. I pulled off two that held brackets and that was a no go...
  2. TRDTUNERSR5
    TRDTUNERSR5 Newbie
    Riverside county
    1988 RN50
    to drain i do think its the big nut in the bottom, and to fill its the one on the side.
    from what ive been told that id easier to fill from the top, where the shifter is at.
  3. rajzswap
    rajzswap Addict
    CA
    89 2jz pickup
    If its manual, theres one at the lowest point of the trans and a fill hole on the side. they should be similiar bolts. dont over tighten. For the fluid you can use GL-5 gear oil. has worked well for me.
  4. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    go to harbor freight and buy a siphon pump they are only a couple of bucks,easiest way to fill the tranny!!..just pump it in the tranny until it comes out and your done
  5. JOE_1985
    JOE_1985 Veteran
    87 custom
    thats what i did, i reccomend if u can to heat up the stuff till its warm or at least leave it in the sun before u do this, just make sure its not cold or you will be pumping forever
