Up for sale is this w50 transmission out of a 2wd Toyota Hilux being sold as is for only $230 shipped! Great value Comes without the shift ball, but will include the bellhousing, clutch fork, throwout bearing housing, external slave cylinder and stick shift! (most transmissions do not come complete with these necessary parts) Transmission came from a toyota corona, has about 70,000 miles and was purchased from a local auto recycler a year ago for $250. Ratios: First Gear: 3.287:1 Second Gear: 2.043:1 Third Gear: 1.394:1 Fourth Gear: 1.00:1 Fifth Gear: 0.853:1 Reverse: -4.039:1 Applications: 1973–1981 Toyota Celica 1974–1981 Toyota Carina 1973–1981 Toyota Corona 1979–1981 Toyota Supra 1976–1982 Toyota Hilux (RWD only) Thanks for your time. PM me or post here.
compare to the average seller asking $250-$500+ shipping 1983 Toyota Pickup 2 4L Manual 4x2 Transmission JDM OE | eBay
I had one of these w50's in my single cab 1987 toyota 2wd pickup truck and the stock driveshaft was the right length; I don't think wikipedia is right about the application compatibility and I believe this transmission will go right in to later year Toyota Pickup Trucks
This is a great unit to upgrade from a 4spd with, to replace your current 5spd, or to use with a divorced transfer case. it'll work in xcab's too. It came with a 6 month warranty and had no problems Price Drop $220 shipped
The chrome stick shift and base plate alone sells for $150 from other used parts vendors so this is a great bargain to get the whole low mileage setup for only $220 shipped to your door
I've shipped many Toyota Transmissions so buy with confidence. Here's one of my latest sales to my Washington Customer SpeltWrong on Pirate4x4.Com - The largest off roading website in the world. MVI 3340 - YouTube Thanks Again Speltwrong on Pirate4x4.Com - The largest off roading website in the world. "Recieved the G series Transmission on Wed 02 JULY 2014. Packaging was very thorough and the unit was not damaged. I installed the transmission in my 1985 Toyota pickup with existing transfer case and parts. Transmission works well and does not appear to be damaged or burned. No strange noises or grinding. Thank you for a drama free order from acrossed the United States! Happy 4th of July!"
Eric, Do you know if there is a difference between 1/2 and 3/4?. Looking to do a 5 speed swap on my 3/4 1980 truck. Planning on using it to tow. Don't really want to go w58 but need tow capacity. Referring to your w50 for 210, have bellhousing.THX. Will
The w55 I have for sale is stronger than the w50. (I sold the w50) $185 shipped with no bellhousing and contents I believe the W series transmissions have the same bellhousing Did you see my for sale thread? the one which is $210 shipped that you mentioned http://www.toyotaminis.com/forum/203575-post130.html
