Filed under: Convertible, Hybrid, Sedan, Recalls, Safety, Crossover, Lexus, Luxury When it rains, it pours. Toyota has announced a pair of separate but voluntary North America recalls covering approximately 235,000 vehicles built between 2006 and 2011. The larger of the two recalls targets Toyota's hybridized crossovers, the Lexus RX400h and Toyota Highlander Hybrid. 133,000 units, including 2006-2010 Highlander and 2006-2008 RX crossovers are covered in the campaign. The other recall affects 102,000 IS350 sedans, IS350C convertibles and GS350 sedans built between 2006 and 2011. With the CUVs, the faults in the parallel circuits of the transistors can cause heat damage in the inverter assembly, triggering an abundance of warning lamps and sending the vehicle into limp mode. The Lexus sedans are being recalled due to loose bolts on the variable valve timing controller. Detected by unusual underhood sounds on startup, the issue can cause the engine to stop while driving. The inverter issue is also triggering similar recalls in Japan and Europe. At the moment, it's unclear if any of these issues have caused any crashes or injuries. Toyota says it plans to notify owners of the recall via snail mail. Additional information for owners can be found on the recall sites for Toyota and Lexus or by calling Toyota's customer service line, at 1-800-331-4331. Scroll down for the complete recall notice from Toyota.Continue reading Toyota and Lexus recalling 235,000 hybrid CUVs and sedans over separate issues Toyota and Lexus recalling 235,000 hybrid CUVs and sedans over separate issues originally appeared on Autoblog on Wed, 04 Sep 2013 10:59:00 EST. Please see our terms for use of feeds. Permalink | Email this | Comments Read More...
