torsion adjuster double lock nut question
Discussion in 'Suspension/Chassis' started by oilspot, Feb 29, 2012.
  1. oilspot
    oilspot Member
    So i went out to the ol' shop to give my 94 x cab a 3/2 drop today. Started with the balljoint flip. That went fairly easily, except it required a trip to the scrap yard to find the correct bolts to reattach the front trailing arm deal (the one with 2 bolts). Somebody along the way reattached that whole deal with some mix and match sketchy hardware!
    While I was in there I pulled the front bump stops, cut them down, cleaned them up, and reinstalled them.
    Now i had read somewhere that 89' and up trucks didn't use a double nut on the torsion adjusters. Well, mine does!?!? And the two nuts don't wanna "unlock" from each other. I must have spent an hour under there screaming and cussing trying to get it loose, and that was just on the one side.
    So first let me clear some things up..... Is the bottom nut supposed to spin? I was under the impression that it was attached and the top nut wasn't.
    Anyway, i tried pulling the two wrenches against each other. I tried putting a long wrench on just the top nut and turning the "adjuster nut" with a decent sized impact.
    I used a cheater bar on the adjuster nut. It all got soaked overnight with rust penetrant "NOT WD40"
  2. gilpet79
    gilpet79 Enthusiast
    MD
    94 2wd
    I can speak for myself when I say I use an impact gun and a wrench, both nuts are locked in place on mine too but it still turns lol
  3. Toy88yota
    Toy88yota Member
    88 2wd
    My bro inlaw and myself had the same experience on my 88 and his 90 2 weeks ago when we put control arms on.
    The nuts would not separate from each other. We had to run them both up at the same time with a impact on the bolt. Taking a wire brush to the threads helps slightly.
  4. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    my 91,92, and 93 are all double nutted. I soaked my with pb blaster for a day. and then hit them with a wire brush. Then got out two big wrenchs that fitted the nuts and smacked the top nut with a dead blow. Took some work but soaking and trying to clean the rust and grit out is needed.
  5. biketrials25
    biketrials25 Member
    Charlotte, NC
    1980 Hilux
    My '94 is double nutted. After an hour or two fighting with mine I resorted to a 4' pipe extension on my wrench. The other wrench on the lower nut was jammed against the frame to prevent it from spinning.
  6. Kahuna
    Kahuna Enthusiast
    AZ
    94 single cab
    Same here...Both of the nuts turns as if it was one nut!
  7. oilspot
    oilspot Member
    Appreciate the feedback! Just didn't wanna break anything. Guess I'll get out the ol' "somethins bout to happen" cheater bar in between classes if I have time today.
  8. oilspot
    oilspot Member
    Working upside down with a big cheater bar sucks. So this was my brainstorm.
    Made it so I could "focus my energy" on pulling. Finally got it free. Passenger side came loose fairly easily. This setup plus a 6' cheater and it was no prob.
  9. nxrunner
    nxrunner Member
    Marksville La. Working in Carbondale IL.
    92 Xcab ~ Rare 2000 XCab StepSIde
    WOW oilspot looks like alot of work... :shrug::eyecrazy:
  10. Chip Morton
    Chip Morton Member
    San Diego, CA
    I just want to say that's a clever solution!!!
    Mine also are stuck together but with an air wrench I can at least turn the bolt.
  11. riceratyota
    riceratyota Veteran
    backwoods oklahoma
    which one 77/78/79/81[r.i.p]82 sbrc driftbox, and a CeliLux/current daily= 79 sbrc [lil' blue]
    nice thinking on jack idea
  12. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    They can be a pain a real nuckle buster
  13. IronNam
    when i did it, was basically laying under the truck and was able to use my legs against the frame to provide leverage LOL.
    Does anyone know what the stock ride height thread length should be?
  14. Gadgedizzle
    Gadgedizzle Member
    Northern California
    92 Toy 2wd Reg cab SB Corvette LT1 6-speed.
    The OE specifications are not based on thread length or anything relating to position of the torsion key.. as they vary depending on sag, weight, and any number of other variables. They're based solely on ride height when equipped with stock size tires. If you've modified tire size, spindle drop, ball flip, you can only measure and calculate what your new ride height SHOULD be, and adjust it to that to retain OE suspension geometry. For ride height specs, you can ask any alignment shop for the specified OE ride height. it's one of the things they check to properly do an alignment.
    (BTW, Ball flip does NOT allow you to drop while retaining your stock geometry since the ball joint is in the same location relevant to the spindle CL after the ball flip.. Therefore, all a ball flip is good for is gaining a little additional drop while using stock bump stops, and possibly reducing angle on the ball joint itself. if you want to drop and retain OE Geometry, the only way to do it with a bolt on is a drop spindle.)
  15. Gadgedizzle
    Gadgedizzle Member
    Northern California
    The OE specifications are not based on thread length or anything relating to position of the torsion key.. They're based solely on ride height when equipped with stock size tires. If you've modified tire size, spindle drop, ball flip, you can only measure and calculate what your new ride height SHOULD be, and adjust it to that to retain OE suspension geometry.
