Tire Size Help
Discussion in 'Wheels/Tires' started by Bkcris13, May 4, 2022.
  1. Bkcris13
    Bkcris13 Newbie
    toyota fanatics...
    current setup :
    2wd on drop spindles with maybe 1-1.5 torsion down
    3in block in the rear with mono leak stock spring
    bought 15x10 wheels with 4.5" backspacing
    i believe offset is -25
    4wd fenders up front also
    wondering what tire size would fit flush with no spacer or with spacer if need be and not stretching the tire?
    i don't want to rub at full lock or anything of that sort either. but i want the fat tire in the rear and maybe slightly smaller in the front or square all around
    thanks!
    current pic of truck also
    Erwin Merida likes this.
  2. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    Sick truck.
    Im setting up similar specs on mine. I'm looking to go between 245/255x40 the only difference in our setups is offset. I should be good at 0. But -25 might be enough to make you go down to 235..
    Have you visited willytheyfit.com
    Bkcris13 likes this.
  3. Erwin Merida
    Definitely roll the fenders!
  4. Bkcris13
    Bkcris13 Newbie
    Erwin,
    thank you! I’m going to check out that site now. I was running some ESR on 18x10.5 and that was stretching a 235 so I’m hoping the 15x10 won’t stretch on that 235/40
  5. Erwin Merida
    Play with the offset feature and compare how much the wheel moves inward to your current set up.
  6. jetas
    235 will stretch on a 10. I had 245s on a 9" wide wheel and that was squared so go with that for reference.
    take a wheel off, load the suspension and measure from the whee mounting surface on the hub to the edge of the fender. That should help get you a ballpark idea of how much barre you can manage to fit up front
