Tire size HELP!!
Discussion in 'Wheels/Tires' started by ToyoMiniGambler, Apr 7, 2014.
  1. ToyoMiniGambler
    ToyoMiniGambler Newbie
    Scottsdale, AZ
    1993 Toyota Pickup
    Just got this 93 pickup for $150.00...Needs head gasket. I also got these 20inch rims for $60! The tires are shot and I need new ones. My question is, The rim is 20x8.5 and it has 235/35/20 tires. I need some with more meat. I am practically riding on the rims, the tires have been stretched out. What tire size will fill up the wheel well without rubbing? Is it 245/45/20, 255/45/20 or ??? THe truck will not be lowered it is stock height. Can someone give me some pointers? THX.
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    If you want more meat... go with a wider tire patch. The 35 series tire is gonna keep you from rubbing. If you insist on having more cushion you could go up into a 40 series and stay with the same aspect ratio. Goodle your rim and different tire sizes to see if you like the look. A tire size calculator will also give you ideas to how much room tires will take up...
  3. ti-driftin
    ti-driftin Newbie
    i think you will be ok with a 245/45/20. Thats about an inch taller tire than the recommended tire height. Recommended tire height is a little over 27" but a 245/45/20 will put you at 28.68" in height. If you want to play it safe. I would go with a 235/40/20. That makes your tire 9.25" wide; and a 3.7" sidewall putting you at 27.4" overall height which is right at spec.
