Tire question
Discussion in 'Wheels/Tires' started by jrknsrk08, Jun 15, 2010.
  1. jrknsrk08
    jrknsrk08 Member
    Sierra Madre, CA
    88 single cab 2wd
    Will 33x10.5R15 BFGoodrich KM2 fit on a stock height 2wd 86 toyota pickup with fiberglass fenders all around?
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    i highly doubt it........ the rear might...... and i mean MIGHT* stuff in but the front wont.. you will run into the rear pinch weld and fender well of the cab when you place it in there.
  3. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    only way is to test it out. are you lifting your truck now ?
  4. jrknsrk08
    jrknsrk08 Member
    Sierra Madre, CA
    88 single cab 2wd
    how about a 30x9.5r15. I just want the wheel wells filled with tire for the time being.
  5. V8_TITAN
    Tampa Fl
    89 std cab
    honestly I doubt you will be able to run more more then a 28'' in height. unless ur bars are cranked up high
  6. SD YOTA
    what he said......... these little 2wd's have very little clearance up front for wheels and tires...... issue will be up front near the pinch weld on the cab. i say a 30 inch tire will fit with some modification and cranked in lift........... dont expect a rub free ride. :waytogo:
  7. jrknsrk08
    jrknsrk08 Member
    Sierra Madre, CA
    88 single cab 2wd
    thanks for thie info
