timing kit question...
Discussion in 'Engine/Drivetrain' started by V8_TITAN, Mar 26, 2013.
  1. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    so I bought a new motor for my truck, its an older 22r motor with dual timing chain. all the kits im looking at say 79 to 82, I was told the motor is an 83, and in 84 they went to single timing chain.. will i be ok ordering the kit for the 79 to 82 motors ??? and do these even really need timing chains like the single row ones do ? the motor was well kept but probably original chain, and the owner told me he scrapped the car and he thought he needed to replace the timing chain but it never made any noise or evidence that it was due..
  2. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    It'll work!
  3. V8_TITAN
    Tampa Fl
    89 std cab
    nice, i figured. I think im just going to drop the motor in and run it for a while untill it has an issue or i save up enough for my v8 swap that ive been putting off forever.
  4. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    IMO - all double chain hardware is the same. all single chain hardware is the same. u cannot swap parts between the two.
  5. Xs5875
    Xs5875 Addict
    Greenville, Ga
    My '82 had a double row. Never had a problem. I remember reading somewhere that they went to single row for cost and to increase service revenue. Lol.
    I doubt it. But good theory.
  6. oldschool64bus
    oldschool64bus Veteran
    Boise, Idaho
    1983 SR5 4x4
    my 77 had a double but my 83 has a single row. Not sure on the double but theres a short and a long single row chain.
  7. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    You can get double row conversion kits and timing covers at LC engineering or engine bldr
  8. V8_TITAN
    Tampa Fl
    89 std cab
    ok I guess I wasnt clear. MY motor IS DOUBLE row. Im not swapping to single. Im just saying that online the kits specify 78 to 82 for double and 85 to 94 for single. the kits that say 83 and 84 on them are mixed between single and double. I want to just order the 78 to 82 kit but i didnt know if there was a small difference in the 83 or 84 models.
  9. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Dont think there is 84 was last year before they went to the laser block so that means your deck height/block height is the same from 1975 to 1984-11.280 inches " so I think your in the clear if u got a new kit from any of the years listed above
    Cause if u got a double row then u got the clearance issue outta the way
    And any of the double chains kits 84 and below should work
    As for the 84 up laser block its deck height is 11.09 < reference for timing chain length differences
    And in all honesty if the chain looks healthy chances are u can rock it for along time my chain has 220 thousand miles on it and yes I reinstalled in my new motor and I beat the crap out of it !
