time for a full 22re build
Discussion in 'Engine/Drivetrain' started by Da_Roach, Nov 18, 2012.
  1. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    I just pickup a 22re long block with 128xxx miles on it. Bought it for a full build in my 92. Motor has never had any machine work done and never rebuilt. Plans are as follows:
    Take block to machine shop with 22repreformance specs and get it prepped .040 over
    Have crank and rods and pistions all balanced
    Assemble short block for all the top end goodies i have been sitting in for 2yrs.
    Any input people that have built motors please chim in. Iam after power and durabillity in the build. Im really looking forward to doing this.
  2. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    there is alot you can do
    just depends on the wallet
  3. Da_Roach
    NOVA
    So just to be clear no boost. Im willing to spent up to 2k but doing all the build with a friend Vicor and just want power and last a good 200k longer.
  4. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    call me stupid, but where's nova and whats the smog laws there. there is a lot you can do but at the same time you don't wanna make it unregisterable.
  5. NashMan
    NashMan Toyotaholic
    94 2wd
    well best bet is to to do the fallowing
    supra afm the adjust theeth for thottle respones there all so an air screw as well
    supra throttle body
    relocate the afm to the battery side
    tri flow header for the 22re with 2.25 exhuast
    msd coil (then open the plugs up)
    use copper plugs
    replace your ecu temp sensor and ox sensore
    fuel regulator
    and most importian a wide band guage so you can tune it with the afm and fuel reglator
    as for inside motor a nice cam/ clean up the ports/ high comp pistons/ add a 5 mill shim to the oil pump and a crank scarper
    one other thing ya can do is pin the oil holes in the rods (to prevent rod knock at high rpms)
    then use a mill and grove your rod this way so you still have some oil jetting to the upper walls for longer ring life
    crower
    stock
    on ya indexing your plugs on 22re helps out alot
    cheers
  6. IronNam
    Old Vicoor should have good knowledge. There's a thread somewhere I left with a ton of info from engnbldr.
    *Btw, how is Vicor and his megasquirt setup??*
    Found it.
    4x4Wire's TrailTalk Forums: 22R/RE: Simple power tips
  7. Da_Roach
    NOVA
    Vicor is good. He had some top end issues and i gave him my lce head so he could be back on the road. His truck is running real good. He was over at my house just a few minutes agk going over my new block and giving me some input for this build.
  8. IronNam
    owch, what was up with his top end on his truck?
    He's still on megasquirt, right?
  9. taki_lalu78
    taki_lalu78 Member
    Ya the budget is everything, Look at my motor I have every performance part you can think of on it,
    12.5 to 1 CP forged Pistons, foged rods, forged stroked and lightened crank shaft, block bored .080 over, pistons notched high volume oil pump, crank and water pulley, stage 5 race prep head, with custom grind 310 camshaft, dual springs, 48 and 40 valves, adjustable timing gear, converted dual timing chain, cannon side draft intake, Mikuni solex 50mm side draft carbs, intake and exhaust port matched, 5 angle valve grind, port and polished, NOS Sportsman wet fogger, 9lb flywheel, ACT 6 puck clutch kit, ARP from top to bottom I can't tell you how much I spent but it wasnt cheap, but lest just say its not even close to LC Engineering Stage 5 stroker race motor,allot less I mean allot about half
