tie rods
Discussion in 'Suspension/Chassis' started by Houa Thao, Apr 2, 2011.
  1. Houa Thao
    Houa Thao Enthusiast
    Sacramento, ca
    91extracab
    I am thinking of replacing my inner and outer tie rod. There are alot of brands out there and don't know which is better than the other. Some are cheap on Ebay. They all come with one year warranty. Which brand should I get for quality and price? Any suggestion?
  2. jetas
    Rockauto.com
  3. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Id say get what they have at napa if not them get somethin that has a lifetime warranty from kragen or pepboys
  4. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Nothing is worse then autozone suspension bits.
    Buy moog problem solvers, and cry only once.
  5. low_toyota92
    low_toyota92 Enthusiast
    Nashville, N.C.
    92 ex cab
    x2 on th moog!! best steering and suspension parts imo!!
  6. Houa Thao
    Sacramento, ca
    91extracab
    Okay so I went and search my garage and found the stuff that came with the truck purchase. I was given two new outer tie rod ends. The thing is one is BECK ARNLEY and the other is MEVOTECH. Are these any good compare with MOOG?
  7. Dux_Trucks
    Dux_Trucks Enthusiast
    campbell CA
    1988 hi-lux std cab 2wd 5spd short bed
    MOOOOOOOG!!!!!!! THEY ARE THE PROBLEM SOLVER!!! UNLESS you go with hemi joints
  8. Houa Thao
    Sacramento, ca
    91extracab
    Well, I gues MOOOOOG it is. I definately want to get it done the first time.
  9. Houa Thao
    Sacramento, ca
    91extracab
  10. Houa Thao
    Sacramento, ca
    91extracab
    Do I need to pack the boots with grease or just put the rods together as is?
  11. n2bnlow
    n2bnlow Enthusiast
    San Diego
    94 Toyota 2WD
    Just buy them, and install. Measure how the ones that are on there now are set up to set the new ones. Moog is what I have also.
  12. Houa Thao
    Sacramento, ca
    91extracab
    Got them on, but know seem like my steering wheel is a little off. Will an alignment fix it or do I have to take them off and adjust them again. Another thing is that when I check the repair manual, it states that the tie rods should be 12.36 inch (314mm) long. Before I took the old one apart, I measure it and it was longer. Went and got measurement from the other truck and it is the same.
  13. Raffaelli
    Houston
    82 Longbed 2WD
    Take it to an alignment shop. Tell them to align it. (Tell them camber/caster too!, They wont because 99% are too lazy).
    Done! At worst 80 bucks.
  14. 78yoda
    78yoda Member
    Knoxville, TN
    78 hilux, 4 speed...blaha
    just purchased mooooog from rockauto.com cheaper than anywhere else i culd find...just received new rear brake drums yesterday for tha T-100 from them as well....
