Ticking sound in my engine?!?! HELP!
Discussion in 'Engine/Drivetrain' started by MENO671, Apr 10, 2013.
  1. MENO671
    MENO671 Member
    Ft. Campbell, KY. (671 Soldier)
    90 TOY STD CAB
    Anyone know exactly what could be causing it? If anyone does. what do you suggest i do? its driving me :eyecrazy:
  2. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    Exhaust leak? Valves? Wrist Pin? Need more information..where is it originating from?
  3. MENO671
    MENO671 Member
    90 TOY STD CAB
    well everytime i step on the gas pedal...i will hear this louding ticking sound as the rpm drops..
  4. Kahuna
    Kahuna Enthusiast
    AZ
    94 single cab
    Timing chain....
  5. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    More than likely the valves lash needs adjusting mileage ? 22r and e's are known for there valve train noise even when there set to spec they still tick a little
  6. CodyX36
    CodyX36 Enthusiast
    Seattle, WA
    '72 RN14
    22r motors also are known for the timing chain wearing out the plastic guides that sort of hold it in place, once they wear through they start rattling on your cover, if it wears through all the way you've got a problem. Had to do one on my old '84 4wd pickup, not the hardest job to do with a good write up, some beer, and a buddy or two haha. Might want to look into it. Then again it could be a large number of things, that's just the first one that popped into my mind
  7. Rcksqrl
    Rcksqrl Enthusiast
    Boise, Idaho
    '85 4Krawler, '67 Stout
    agree with above. Valves should do it all the time. My timing chain on 22re was making the noise most of the time.... by the time it was removed there were only 4 teeth on the gear holding the chain on....... got real lucky on that one!!
  8. MENO671
    MENO671 Member
    90 TOY STD CAB
    Appreciate all the advice everyone. Will work on it and update you all as soon as its done. THANKS AGAIN!
  9. williyumz
    williyumz Enthusiast
    My 22re had a busted driver chain guide that made noise, I suggest getting a metal backing guide instead of the cheap plastic ones, hope you don't have to do so much.
  10. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    not sure whats going on here, but i know in my truck, when i step on the gas pedal, the rpm's go up. just saying. idk if anyone of u guys ever experience this problem before. :D
