thermostat
Discussion in 'Maintenance/Repair' started by hightolow, Jan 22, 2010.
  1. hightolow
    hightolow Member
    south jersey
    95 standard cab
    guys, im replacing my thermostat finally went bad its the original i believe its marked 88c which converted to f is 190. was searching auto parts stores and found all kinds of different temps available. the only one i found that matched 190 is at napa part number atm1542404 . or is 180, 195 better to use or should i stick with what was in their. thanks guys
  2. Nook
    Nook Addict
    oregon
    The only temp ranges I have ever been able to find were 160' special order, 180' used in the earlier carbed trucks, and 195' used in the EFI models, I would stick with the 195 probably:shrug:
