The proper way to install ring terminals.
Discussion in 'Interior/Electronics' started by GrantH, Nov 4, 2011.
  1. GrantH
    GrantH Addict
    Hattiesburg, MS
    First, put your terminal in a vice.
    Then, strip your wire about 3/8 of an inch i'd guess.
    Then heat the crap out of your terminal with a Benzo torch. Takes a bit, but it will get there. Once heated, push your solder into the lug and let it pool up inside.
    Once it's pooled up and still liquid/hot, push you wire in for a few seconds and remove the heat while doing so. The solder will firm up.
    Then, last but not least (most importantly, really) heatshrink everything tight.
  2. gilpet79
    gilpet79 Enthusiast
    MD
    94 2wd
    Wait you dont simply crimp the wire hahaha j/k :ROFL:
    Good write up :waytogo:, I hate to see nice things installed then when you really look its a cluster f*** of wiring behind it.
  3. GrantH
    GrantH Addict
    Hattiesburg, MS
    That's what i'm fixing :). We threw the truck together so I could drive it, now everything is getting sorted.
  4. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    this is how I make mine
    open ring termial solder then capped with solder no crimping
    takes a abit on how to do it but it looks killer and is stroung as hell
