The elusive W52
Discussion in 'Engine/Drivetrain' started by cascade_crawler, Aug 27, 2010.
  1. cascade_crawler
    cascade_crawler Newbie
    everett
    84 EFI 2WD X-cab
    Long story short...picked up an 84 EFI 2wd xcab pickup off of craigslist. The tranny is in need of a rebuild so I have been trying to find a good used replacement, which is turning out to be a pain. I have confirmed off the placard in the engine bay that I have a W52. Through some research this looks to be a pretty rare tranny mainly used in Australia. The local junkyards have some 2wd trannys but they are an inch too short, thinking they must be W55's.
    Are there any trannys that would be a direct fit to replace the w52? Any recommendations on who to call or where to look that may have one?
    Thanks! :verdict_in:
  2. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    all the w series transmissions are interchangeable.... you can just put anyone you find for cheap in there. they are all about the same length and the snout of the drive shaft should more then easily make up the inch difference...
  3. 22R_All_Motor!
    22R_All_Motor! Addict
    Houstone
    84 pickup
    yea i think alls you have to do is use your old bell housing... someone correct me if i am wrong :)
  4. dillinja666
    i dont even think that, if he gets the trans off a 22r it bolts right up..
