Taking a lift off???
Discussion in 'Suspension/Chassis' started by yotabeast12, Aug 14, 2008.
  1. yotabeast12
    yotabeast12 Newbie
    How hard is it to take a suspension and body lift off and how much would it cost???
  2. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    probably a few hundred to get it taken off, or half a day in your drive way with a buddy, some beer and hand tools
  3. Predracer
    Predracer Toyotaholic
    Conyers, GA
    Long bed 80 2rz turbo machine
    Yeah it'll be easier to take one off than it is to put one on so if you have help and are mechanically inclined it might take you half a day to do.
  4. 91HiLux
    91HiLux Enthusiast
    Paradise Valley, AZ
    1991 Toyota HiLux 4x4 RN101
    Taking a body lift off is really easy!
    It is really simple, and you could do it yourself!
  5. lownloud
    lownloud Toyotaholic
    Plains, Montana
    Not only is it easier than installing, but, with doing it yourself you will learn more about your ride and maybe learn a thing or two, PLUS, youll save some dough . . .
  6. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    to undo this you gotta have the stock bits needed to go back.
    go to a junkyard and grab the body mounts n bolts from any truck. just take the nuts off of all the ones on the cab then jack up one side, take em out then jack up the other.
    the suspension could be tricky if you have different springs. so you'd have to find stocker ones.
    how was your truck lifted suspension wise?
  7. 91HiLux
    91HiLux Enthusiast
    Paradise Valley, AZ
    On the 89-95 Toyota truck, the body lift sits on top of the body mount...
    But since your going to be in the area of the body mount, get the poly cab mount kit from Downey:
    http://www.downeyoff-road.com/SuspensionComponents/Polyurethane.html
    Also when removing the body lift, its all about removing all the spacers, the only thing you will need to get is new mount bolt for the cab and bed, and then new bolts for the steering shaft.
