Tach Install
Discussion in 'Interior/Electronics' started by SomeToyota, Feb 1, 2011.
  1. SomeToyota
    SomeToyota Newbie
    South Bay
    92 pickup
    so i got my hands on a autogage 5' tach gage with shift light. i know it can't be hard to install but id rather play things safe and see if anyone can tell me the best way to install it. its your standard 4 wire tach, white (12v dash light), red (12v ignition switch), black (ground) and green (ignition coil neg). now the black and green are simple but its the white and red i need help with. im trying to find what wires to tie into under the dash. any help would be appreciated.
  2. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Hey man I did mine it was pretty simple although I had the same problem finding somewhere to attach the red and white cables im in class right now but ill take pics later to show you where I attached them
  3. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    white only has to go to the existing dash lighting if you want to dim it with them. otherwise you can leave it off (no light) or run it to the B+ source you use for red (on whenever the truck is). As for the red, you can get creative. I'd suggest something that's on with the accessory position...like the radio. or on with the run position like the ECU. You do have wiring diagrams in this class of yours?
  4. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    just put those wires in the fuse box, take out your gauge light fuse or something put the wire in and put the fuse back in, do the same for ign. thats what i did when i had an aftermarket tach
