T-case change help
Discussion in 'Engine/Drivetrain' started by planemos, May 1, 2010.
  1. planemos
    planemos Toyotaholic
    British Columbia
    Hi I was wondering how difficult it is to change out a transfer case. I have an 19 hundred and 88 4wd extra cab.
    If I go and unbolt it will fluid pour everywhere? What's the best way?
  2. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    they are pretty simple, basically yes just unbolt it and slide it off. I drain the fluid from it as well as the trans just for the fact that its going to be a new tcase with new fluid, might as well put new fluid in the trans as well. If you are installing a used tcase you are going to put new fluid in it anyways so still change the trans fluid.
    Also make sure you get a new gasget for between the tcase and trans.
    beer..lots of beer :)
  3. planemos
    British Columbia
    Okay thanks
  4. planemos
    British Columbia
    Well I have a spare case but may be able to fix this one. It still works but it is hard to get it out of 4wd (h4 to h2). I used to drift in the winter time and change to h4 mid-drift to gain traction.
    So I was wondering if I can work on it without taking it off the truck?And if I'm that lucky what could I replace (besides oil) to fix the shifting problem? Maybe a spring?
  5. dillinja666
    well those tcases dont have syncros in them like it transmissions....so im pretty sure you buggered the gears inside it..which mean you need to pull it, and crack the case. I would go through the spare case while its out of the truck, make sure its perfect and then just do a tcase swap...probably easier then trying to mess with the other one.
  6. planemos
    British Columbia
    Yea I guess taking the spare one off my parts truck is the best way for me to learn how it works. I found LCEngineering has a nice looking rebuild kit for transfer cases too. I don't know if I want to spend much that's the thing.
  7. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    if you get a chance look at marlincrawler.com as well.......
    shifting from 2wd hi to 4wd hi should not hurt things as long as there was enough slack in load to permit a smooth transition....... ive done it in snowy roads on allot of my trucks.... never hurt anything...... but like i said, its gotta be right in order not to hurt anything....
