Hey i picked up this hilux truck and im startin a drift build wondering wat rear end we be easiest to swap for an lsd
You already have an 8" diff with 30 spline axles so just put a tru trac or swap to a V6 3rd and put a turbo supra limited slip in it.
Well, he may have the 8". If you don't mind the extra 6" of width, an explorer 8.8" can be swapped fairly easily. There's a writeup on doing it into a 89-95 truck. Or you can find a LSD diff from another 8" Toyota. Either 2 or 4wd trucks are the same center pumpkin just diff axles/bolt patterns.
