Suspension Refresh & Considering 2" Lower - Question
Discussion in '1989-1995 Pickup Discussion' started by Bradley Allen, Feb 28, 2021.
  1. Bradley Allen
    Bradley Allen Newbie
    Colorado
    94 Toyota Base 2wd
    Hello!
    94 Base 2wd. Daily Driver.
    I'm currently in the middle of replacing ( basically the entire front end ) due to East Coast rust. I have a couple questions!
    Most of my replacement parts are sourced from Moog by way of Rock Auto:
    Ball Joints, End Links, ETC.
    UCA / LCA are OEM Replacements from Dorman.
    Replacing basically all rusted bolts - sourced from Toyota.
    Front and Rear Shocks - BILSTEIN 4600
    I'm now looking at lowering about 2 inches front and rear.
    Front using Belltech Drop Spinals
    Rear 2inch Lowering Blocks.
    Can I lower using the new shocks while using this lowering equipment?
    Will I rub with 195 /75 R14 tires. ( again stock ).
    Overall thoughts on MOOG for OEM Replacement?
    Thanks!
  2. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Moog & Belltech are the best choice
    The shocks should work unless you go lower
  3. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    Make sure the Moog ball joints have castle nuts. i used moog balljoints on my first truck that only had nylock nuts. There is a nice 16' gouge in the asphalt around the roundabout in Fort Bragg CA from my right control arm when that nut came off.
    Bradley Allen likes this.
  4. Bradley Allen
    Colorado
    94 Toyota Base 2wd
    Thanks - they came with Castle Nuts, although...they seem like they could use a heavier material.
