suspension bracing
Discussion in 'Suspension/Chassis' started by Kristian43, Mar 21, 2011.
  1. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Ok so I've been looking into putting some suspension bracing on my truck to add some stability/rigidity. I have access to all the materials to do it but not a great idea on how to brace it. So far I've come up with an 'X' going from the right to left frame rails in the center of the truck. Besides that any ideas?
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    what are your suspension goals? making the frame stiff will only get you so far....... suspension is gonna make up the other half of your rigidity.
    from what i can tell, there is a massive gap where the motor and tranny sit.... mostly the front end portion.
  3. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    You do know that the frame on these things are CRAZY tough.
    Your gunna be wasting your time man. :waytogo:
  4. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Goals are I want the frame to not move at all almost
    suspension upgrades are gonna happen but I wanna make sure my frame is good first
    Just weighing my options.
  5. jetas
    U know an extremely rigid frame is bad right? It needs some flex otherwise it could crack
  6. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Yup I know all that already #1 im not gonnabe putting tons of weight or jumps with it so I know ill be fine. Im just lookin for ideas on how to brace it
  7. Twisted Minis
    Twisted Minis Addict
    Poor Cal
    1980 Toyota
    Bracing mostly for my rear link setup, to keep the cross member rigid since it will see a lot of force, not necessarily to stiffen the chassis under the cab (this is your least flex worry area)...
    Your biggest flex points will be right in front of and behind the cab/firewall. The area between here and where the suspension load is concentrated is the most loaded part of your frame, and generally where most of your flex comes from.
  8. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Thank you sir :waytogo:
