Suicide doors
Discussion in 'Exterior/Body' started by yota4life, Sep 3, 2010.
  1. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    So I've been thinking I want suicide doors again ( had them on my Mazda) and I was wondering how hard it is to do using one of the kits they sell. Anyone on here ever done it?
  2. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
  3. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    If your going to use a kit ,use the one from SuicideDoors .com
    I done two one with a kit & mine stock hinge & latches.
    The kits swing the door to the outside ,stock hinge swings inside the body line!:cool:
  4. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Ya I saw yours I like it alot. I was thinkin the sd.com kit aswell or the Carolina customs one which I heard is the same as sd.com how hard was it to do using a kit
  5. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Not bad,go to SuicideDoors site & print out the how to & study it.
    The first side took 4 days the second side two.
    Make sure to plate the door & add bracing behind the pockets inside the cab.
    All the finish grinding is where most of the time is!
    Consider installing safety latches, as I have heard more than once of the Bear Claw type latches failing, & the door opening & any speed will do a lot of damage!! :cool:
  6. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    I have been reading alot on it an just trying to figure it out. Doesn't seem to hard at all just time consuming
  7. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    It is a lot of work! Most shops will charge around $1,800 per side ,this is with a kit,not stock hinged!:cool:
