Sub Models of a Toyota Pickup
Discussion in 'Engine/Drivetrain' started by 387MP, Nov 8, 2009.
  1. 387MP
    387MP Newbie
    I'm getting ready to buy a Toyota Pickup 4 cyl. 4WD Auto tranny. The engine is blown and i didn't know if i needed to know the sub model like sr5, dlx or not? Whats the difference between the two and does it matter what 2.4 lt engine i buy for it? Can you tell me what submodel it is also? I attached a photo of the truck.
      File size:
      11.2 KB
      193
  2. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    I would guess thats a dlx. Does it have power windows or anything? The sr5 is the higher end model.
    As far as the motor, it depends on if you want a carborated (22R) or fuel injected (22RE). The motor should say either 22R or 22RE on the front.
  3. jetas
    Ive been wondering this also. Cuz supposedly mine is an SR5 but theres really nothing special about it. No power anything. all i have is a tach. lol
    And where the 22RE and 3VZE the only engines offered in the 89-95 models?
    I tink i kno the answers but just want to clarify for my personal
  4. NMTOY
    NMTOY Member
    NM
    92 extracab, 86 4runner
  5. 93Yoter
    93Yoter Addict
    Central Point, OR
    93 std. cab deluxe
    if it's a 4cyl it's a 22re (22r was gone for 4wd by that year). It does not matter whether it's a dlx, or sr5 except for oil pressure sending unit. Yours is likely an sr5 if you have a tach in the stock cluster along with oil pressure and volts. Just buy any late model 22re (after 85) and you'll be good to go.
  6. nvrenufedge
    Caldwell, ID
    bagged '93 std cab
    I've seen some 89-91's with the 22R, unless it was a swap.
  7. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
    im pretty sure that the 85+ 22r and 22r-e blocks and head are exactly the same only diff is if u get the 86-87 Turbo witch has a different head on it correct me if i am wrong but im pretty sure im not...
  8. 93Yoter
    93Yoter Addict
    Central Point, OR
    93 std. cab deluxe
    2wd yes but I have yet to see a 4wd with one
  9. nvrenufedge
    Caldwell, ID
    bagged '93 std cab
    True.
    I did find a 92-95 4runner with a 22R on a Washington craigslist a few days ago, must've been a swap.
  10. Evolmotorsports
    Evolmotorsports Veteran
    SCV cali
    1987 RN50 Hilux
    the oldest 22r non injected motor was the 89 2wd, the oldest 4wd was 88. the dlx and sr5 are the same as all other toyota models, the dlx is a step up from the stripped model, the dlx has the cig lighter, cloth on the seat, radio, a/c, rear slider,and p/s were an option, the sr5 had ps, a/c, pw, pdl, carpet, carpet door panels, cloth door panels, clock, pin stripe, defrost, rear slider and moon roof were a option.:waytogo:
  11. toyotarnfreak
    toyotarnfreak Member
    Wingate, NC
    89 std cab
    mine is a 89 22r just puttin in my 2 cents
  12. Poorboy
    Poorboy Newbie
    Northern VA
    95 hilux 2wd 87 hilux 4wd 79 F-100 2wd
    It was 85 or 87 was the last year for the 22r. I have 4wd that was only made for a half a year. 22re but with the straight axle. Made right when they went to the 22re and the last of the solid front axles.
  13. IronNam
    several 89-91's had the 22r.
