stock carb to 40mm sidedrafts
Discussion in 'Engine/Drivetrain' started by kankster671, Mar 21, 2011.
  1. kankster671
    kankster671 Newbie
    ga.
    88 yota 22r p/up
    can anybody help me out i wanna change out my stock carb to some 40mm sidedrafts also what vacume hoses can i clip or plug... thanks
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    when you go to the side drafts, you will be changing out your intake as well....... many of those vacuum hoses will no longer be needed. the only hoses you will really need be concerned about will be your pcv, your vront valve cover vent tube, your brake booster vacuum line, and maybe your distributor vacuum lines (depending on how you run your timing).
    there are a few pictures here and there of setups for reference on how this will look. take a look around and search "side draft"
