stock 84' pak pak guahan
Discussion in '1984-1988 Build-Up/Project Threads' started by malofa, May 10, 2011.
  1. malofa
    malofa Newbie
    taotao guahan , truck is 84 with 275,000 miles ,,,daily driver right now,so far i got turbo rims ,soon install msd, saving for a lightened flywheel and clutch to put in my gts celica trans. really want a 4x4 but love this as for my daily driver:)
  2. Ezikiel37
    Ezikiel37 Enthusiast
    671 to 415
    90 xcab 2wd
    hafa adai, no drop? looks real clean/mint
  3. malofa
    malofa Newbie
    maybe later gonna drop it,only if i find a set of weld prolites :)
  4. jeremystephens
    jeremystephens Enthusiast
    mississippi
    94 xcab
    i like those wheels on it.... just work on the stance and drive the tar out of it... its really clean from the pic
  5. malofa
    malofa Newbie
    finally got around to build my other engine....got tired of adding coolant from the bad head gasket..hehe, painted the engine bay satin black,masking paper sponsered by harbor freight! 5 speed celica gts trans is in already....It was pretty easy,didnt have to modify the deck for shifter,speedo cable screws right in,only mod was to cut the trans mount bracket and add a flat plate to screw all 4 bolts.
  6. malofa
    malofa Newbie
    engine, decided to paint it cast iron instead of the usual black. idk about the valve cover,thinkin gloss black or veiny gray:)
  7. malofa
    malofa Newbie
    some progress:)
  8. malofa
    malofa Newbie
    learned a lesson ... okay the engine was running smooth,but was starting to hear light knock on upper portion of block....I was scratching my head for sure:runaway:. So I took a cam and looked inside the chamber and saw some eyebrows on the piston,,,,I was saying ""oh s**t"!!!! so long story short, head was resurfaced at the machine shop,plus the lift on the cam made the valves hit the piston.luckily not enough to bend the valves.:brickknock: I put the stock cam in and all is good,no touching,engine runs smooth . next time I will do valve to piston clearance!!! coulda been an expensive lesson if I ran it like that for long!!
  9. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    Im going thru the same thing right now. Im running a web 292 and valves were hitting the top of the pistons so I went ahead and replaced valves and Im just waiting for a dual sping kit to come in from LC.
  10. tyme_fo_play
    tyme_fo_play Addict
    94 BLOCK HAWAII
    MY PRIDE MY JOY MY TOY!
    Clean truck.
