stereo help
Discussion in 'Maintenance/Repair' started by cEElint, Jan 22, 2008.
  1. cEElint
    cEElint Enthusiast
    Bakerstink, CA
    '91 Yota STD
    .. alright.. i went to put my CD player in my pickup and the power cord plug fell apart when i unplugged it from the craptastic tape deck in there.. .. .. from looking at it, it doesnt seem that i'll be able to splice it back together
    thoughts on this??
    will i need to replace the whole cord??
  2. Darrin87
    Darrin87 Member
    Yulee, FL.
    87 xcab long bed 22r
    the pic you attached is your radio antenna go to a junk yard and and get a new antenna cable and replace it. not that hard to do
  3. cEElint
    cEElint Enthusiast
    Bakerstink, CA
    '91 Yota STD
    would this cause the radio to not come on?
  4. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    no it wouldnt, check and make sure u have power from the red wire (constant powere, ignition on or off) and the yellow(?)(ignition on) and yeah just go to junk yard and get another antenna. hope this helps. also if ur just replacing the deck and not rewiring new speaker wires get the adpater for ur stock wiring, makes things alot easier ( that is if ur wires arnt fried, like mine were).
  5. Litneon
    Cocoa, FL
    94 xtra cab
    If the only ground to the radio was through the antenna cable, it will make the radio not work correctly. Make sure that it has an adequate ground.....
  6. cEElint
    cEElint Enthusiast
    Bakerstink, CA
    '91 Yota STD
    yea, i bought the wiring adapter.. but, the person who installed the other radio hacked off teh plug and wired it straight into the factory harness.. i'm gonna go back and check all the wires again tomorrow
  7. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    hmm..what yr truck is your truck? as log as u have the power wires and a ground ur good, to tell what color ur speakers are just look for the ones that have the same color, with one having a black on it[purple and a purple with black]. if u can take a pic of ur wires and i can go from there...
  8. cEElint
    cEElint Enthusiast
    Bakerstink, CA
    '91 Yota STD
    its a 91... and i have the factory wiring schematics so matching the wires to the correct ones isnt a problem
  9. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    ok, well i hope i helped in some way :}
  10. OGtoy
    OGtoy Enthusiast
    Oahu, Hawaii
    93 std cab 22re
    the red is ignition and the yellow is the constant power.
  11. J-Dizzle
    J-Dizzle Newbie
    NC
    1992 2wd reg,cab
    ive always found that just replacing an entire wire is the best bet
    because when u start to rig and splice wires
    u have the possibility of problems down the road
