ok sooooo what shocks are you guys using for the front. and where do you find lowering LCA's? also bj flip? i see you just mount it to the top of the LCA instead of the bottom any control issues?...... thx guys this is what I'm going for
Welcome. Check out SD Yotas ball joint flip in the " How to " section. As for the LCA's check out JDM. They will have what you need. As for shocks I'm not so sure myself. I'm sure someone else will chime in.
I'm running the KYB monomax all 4 corners. Love them. Have the DJM LCA, drop spindles and BJ flip. I've had no ill effects from the BJ flip. I did flip the mounting of both the top and the bottom.
oh iv only seen instruction for the bottom bj flip but the tops look super easy and it makes sense for that extra inch.
