Static drop
Discussion in 'Suspension/Chassis' started by 93Yoter, Feb 5, 2009.
  1. 93Yoter
    93Yoter Addict
    Central Point, OR
    93 std. cab deluxe
    Ok so I have 2" drop spindles and 2" drop blocks installed on my truck now but would like to go a little lower. Call it another 2" all the way around. I want to maintain as much stiffness as possible in the suspension for performance reasons. So in other words I don't want to crank the torsions so what are my other options? The only lower control arms I have found are 3" and I think that might lower it too much. I need to be able to go crank to crank without rubbing on the fenders etc.
  2. trap
    trap Addict
    orange county ca
    92 pickup
  3. lownloud
    lownloud Toyotaholic
    Plains, Montana
    Well, an easy idea/project is to flip the balljoints if you havent already - Unbolt from bottom - bolt to top - easy for an inch, did it on my 87' without a hitch . . .
  4. 93Yoter
    93Yoter Addict
    Central Point, OR
    93 std. cab deluxe
    I plan on getting the aftermarket torsion bars but I want them to be as stiff as possible so I will be leaving them tight.
    so the bj flip.....
    how does that effect handling, alignments, etc
    what are the negatives?
  5. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    essentially it doesnt affect alignment.
    but....
    it seriously changes the load carrying capabilitys of the front suspension. your entire front load will be held up by the 4 balljoint nuts. imho its a good way to die.
    i really dont reccommend flipping balljoints. i know others have done it with no problems, but its asking for trouble. and in spirited "performance" driving its just asking to fail at the worse possible time.
  6. 93Yoter
    93Yoter Addict
    Central Point, OR
    93 std. cab deluxe
    that's what I was wondering..............
    I will be running large tires and autocrossing so I don't want to break suspension stuff
    anyone know someone that builds custom lower control arms?
  7. IronNam
    coulda said that earlier....
    now that my truck broke off one of its joints...
    j/k, my truck doesnt run =]
