starting problem
Discussion in 'Maintenance/Repair' started by 4serge, Nov 12, 2019.
  1. 4serge
    4serge Newbie
    1980 SR5
    Greetings, another starting problem here with 1980 Pickup.
    I turn the key and it takes three-four attempts to start cranking.
    With Li jump battery hooked up, it starts right away.
    New battery - did not help, a new starter - the same thing.
    I understand that 1980 does not have a starter relay?
  2. fred heath
    fred heath Addict
    Raleigh, NC
    Check your contacts at the starter. Clean everything up with sandpaper or wire brush. Starters need a good ground to work correctly. Also check the chassis ground wire from the block to the chassis, and (-) battery cable where it attaches to the chassis. Clean these up with sandpaper.
    If all else fails, run a separate hard ground wire from the starter (use a mounting bolt) to the chassis.Your starter solenoid is attached to the starter motor. Again, clean all the wires that attach to this also.
    4serge and jetas like this.
  3. jetas
    Mine was doing this a short while ago. Alternator belt was loose so it wasnt providing any current on startup.
    4serge likes this.
  4. 4serge
    4serge Newbie
    1980 SR5
    Thanks a lot for replies! I will work on the grounds and check alternator!
  5. Liquidhandwash
    Liquidhandwash Enthusiast
    Northen VIC
    1980 diesel
    Could be the ignition switch is getting worn out and can't provide enough current to the solenoid. It is worth putting a relay on the starter, it will work better than stock and cheaper than a new ignition switch.
  6. fred heath
    fred heath Addict
    Raleigh, NC
    Forgot to add the basics. Double check your battery top posts. You should not be able to rotate them in either direction once tightened. If they move, you’re not getting a solid contact.
  7. 74RN22
    74RN22 Enthusiast
    Warner Robins, Georgia
    1974 RN22 Hilux
    These are from the 1980 Toyota Pickup Repair Manual...
    Hope this helps...
