Starter Problem
Discussion in 'Engine/Drivetrain' started by NOBODY IMPORTANT, Nov 13, 2010.
  1. NOBODY IMPORTANT
    NOBODY IMPORTANT Newbie
    Rock Springs, Wyoming
    1979 20r 4x4
    :shrug:Have owned many cars/trucks. Never had this one happen....sometimes truck starts grand. Sometimes starter makes no sound and won't start. Sometimes the starter grinds like I already have it started. Con-freakin'-fused!
  2. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    no clue, maybe new starter is going to be needed soon.
  3. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    it might be your ignition swtich (lock cylinder is technical term) when they start to go bad they will do wierd things. have you tested the battery? you can get the starter tested off the truck also.. hope this helps
  4. V8_TITAN
    Tampa Fl
    89 std cab
    the only thing they will check is if it engages and spins.. not gunna do him any good sine it does that.
  5. V8_TITAN
    Tampa Fl
    89 std cab
    I have a used starter you can have for 30 bucks shipped usps. let me know.
  6. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    It seems this is a regular problem. Not enough voltage to the starter! Can be fixed by installing a Ford starter soleniod.
    See my photo's & post on this subject!:cool:
  7. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    that depends on the guy doing the testing, when i tested them at advance you can hear the difference between a good starter and one going bad. But that does take abit to figure out. Hope you get the problem fixed
