The standard wheels are as follows: 1) 16x7 +18 offset 2) 16x8 -10 offset Then there are the rare, expensive Special Handling Package wheels (SHP). 1) 16x8 +18 offset 2) 16x9 0 offset
all depends on how much of a drop you have....... you go anywhere past the 4/4 area its questionable depending on the width of the wheels you get.
The wheels would be 16x7 +18 offset and 16x8 -10 offset. I only have a spindle drop in the front which I think is 2" and the back is stock. Will these fit?
they fit perfect for me im lowered about 5 in front and 4 inthe rear. I just rolled the rear with a wood bat just in case
technically you can pull the bedside instead of rolling the fender (possibly chipping the paint) there are 2 bolts that hold a bracket in line with the wheel and are under the well cover. undo the 2 bolts, move them over to the holes further out and it will give you another 1-1.5 inches of width.......... this will get you the width they set them at for the 4x4 trucks
I had to removed that small bracket inside of wheel well I get in the way when rolling. If you worry about chipping the paint heat it up a little with a torch or heat gun
