Squuuuuuuuuuuuuuek!!
Discussion in 'Suspension/Chassis' started by TSLUX, Feb 14, 2010.
  1. TSLUX
    TSLUX Member
    WAIPAHU
    90 xtra cab
    IDK WHATS MAKING THE SQUEEK, MY THOUGHTS LEAD TO BALL JOINTS. BUT I DONT WANNA SPEND AND ITS NOT THE RIGHT THING.
    WHEN I PUSH DOWN ON THE DRIVER FENDER IT SQUEEKS. SO WHEN I DRIVE ITS VERY ANNOYING.
    ANYBODY GOT IDEAS?
    :shrug::shrug::shrug:
  2. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    could be the control arm bushings
  3. planemos
    planemos Toyotaholic
    British Columbia
    Maybe it`s the fender hitting the door. I know mine sqweeeeks like that. Sometimes the fender bolts near the rocker panels rust out.
  4. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    thats actually a good tip. check for loose body panels. but if it does it when you push the corner of the truck down, its usually a dried out bushing. try hosing some litium grease spray onto all the bushings overnight, then again in the morning. right after you do it...cycle the suspension by bouncing the truck up and down like you did to test it. get it going pretty bouncy. itll help it work into the material. if they look pretty tore up replace them, and use the thicker litium grease (not just the spray). it could also be a shock making noise, but its usually bushings.
  5. TOY|STORY808
    TOY|STORY808 Enthusiast
    WAIPAHU TO LAS VEGAS
    1985 TOYOTA PICK UP
    see what i tell boy...
  6. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    :funnyup: You must have allready told him this before he posted.
  7. TSLUX
    TSLUX Member
    WAIPAHU
    90 xtra cab
    so i bought the spray, sprayed everything, tested it and was squeeking but very softly:) so thats a good sign. so im gonna let it sit, use it, and re spray again later.
  8. standardbyker88
    lynnwood, wa
    sweet. glad it helped out. just keep doing that and the rubber should soak it and work it in. bet its alot nicer to drive now. lol. that reminds me, i have some squeeks on my trucks to take care of today.
  9. TSLUX
    TSLUX Member
    WAIPAHU
    90 xtra cab
    Haha thanks for the help! I was getting irrittated.
    It did come back though, will spray tmrw. Hopfully it'll go away.
