squeky noise
Discussion in 'Suspension/Chassis' started by yota4life, Sep 15, 2009.
  1. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    ok i noticed this the other day but when i make like lets say a u turn i hear this like squeeky noise or like a click
  2. Toyo Trucker
    Toyo Trucker Addict
    Fragment (consider revising):rolleyes2:
  3. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    idk how to explain it really... just when i make a u turn it makes this like click or squeeking noise
  4. thundering02
    thundering02 Addict
    Fenton 63026
    You are attempting to describe a noise, there of regarding a 20ish year old truck, over the internet.
    Please be a little more detailed.
    Such as : where is the noise approxamatly coming from?
    What exactly is the noise, squeek, click, groan? (mine groans upon twisting of the frame, Mine also clunks going into reverse due to the driveshaft ujoint)
    Also we are forced to assume that you are dealing with the 91x cab in your ID.
    Hopefully this will help all.
  5. Toyo Trucker
    Toyo Trucker Addict
    My money is on the caliper.
  6. Toyo Trucker
    Toyo Trucker Addict
    Just for ****s and giggles, you should take the front end apart and put it all back together. All you need is some red thread lock.
    Hopefully the sound will dissipate.
  7. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    i think its coming from the passneger side but ill listen tomorow. srry for being so short on it i just didnt know how to explain it
  8. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    why would the caliper make the noise
  9. bootleg
    bootleg Enthusiast
    Oregon Coast
    1990 4-speed
    my 88 made loud clunking noises on a hard turns while in reverse, it did it at les schwab's tire store and the guy told me it was the rubber bushings in the front end were going bad:shrug: I never fixed the issue before the truck died so I'm not sure if he was right or not
  10. rajzswap
    rajzswap Addict
    CA
    89 2jz pickup
    Mine is doing the same thing. when I make a turn anywhere from 1/2 or more of a turn in either direction and hit a bump it makes a really loud squeek. watch my video of my truck I posted at night, you'll see when I make the u turn in the road it makes a loud squeek. I think a lot of it has to do with the heavy 2jz engine. but my guess is its in the steering somewhere.
  11. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    ill have to ask my old auto shop teacher
  12. IronNam
    hm..... dont think i've ever made anything like that
  13. Lil' Beast
    Lil' Beast Member
    1990 SR5 Extra Cab 4x4 Auto V6
    Well my truck's CV axle on the front passenger side was making grinding noises due to lack of grease because of a torn boot. Then I had the mechanic lob in a bunch of grease and no noise for the past 3800 miles.
    I suspect replacing all the front end bushings on my truck would help in the whole steering affair. I did give the Lil Beast new shocks all around and it rode much nicer than with the original 200k mile ones it had!
  14. 562Tacoma
    562Tacoma Newbie
    Long Beach area, CA
    1987 Pick up 2.4L carb
    2wd do not have CV axles so that wouldn't be the problem for the noise, I have the same similar noise. I put on shocks and the noise diminished but when the truck goes over a big enough whoop-dee-doo it will this make the same squeeking. I still have no clue what it could be :confused: . Suggestions anyone? :thinking:
  15. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    +1 for make clearer posts using some semblance of English and grammar.
    I've heard of the steering stops making clicking/squeaking noises too. next would be bushings. Ball joints tend to make noise over bumps more than turning.
  16. planemos
    planemos Toyotaholic
    British Columbia
    The sway bars. I'm bagged and I don't have that sound. And I don't have a sway bar. I have owned more than a few Toyota trucks. My best suggestion is sway bar. So replace those bushings. Or grease the crap out of them if you're cheap.
  17. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Well mines bagged aswell so no front sway bar. It's coming from my control arm. I have cando arms. I took the bolt out an put anti sieze in there an it still does it. I'm gonna take them out again an add more if not I think it might be my balljoints
