spraying oil from valve cover berather???
Discussion in '1984-1988 Build-Up/Project Threads' started by Dux_Trucks, Aug 12, 2011.
  1. Dux_Trucks
    Dux_Trucks Enthusiast
    campbell CA
    1988 hi-lux std cab 2wd 5spd short bed
    any know whats up with this???
    what im working with
    84 22R
    weber 32/36
    k&n breather filter
    NEW pcv valve (run to the weber supplied bung )
    IT COVERED MY WHOLE ENGING BAY THAT I JUST CLEANED AND PAINTED .... :(
    I NEED HELP CANT SEEM TO TRACK IT DOWN
  2. Dux_Trucks
    campbell CA
    Oooppps posted in wrong place lol sorry
  3. Dux_Trucks
    campbell CA
    ANY IDEA'S FROM ANYONE?????
    I DONT GET WHY THE INLET IS BLOWING OIL AND THE PCV VALVE IS NOT EVEN OPENING .....
    iM AT A LOSS .... WHEN i BOUGHT THE MOTOR IT WAS FINE I DROVE IT NO SMOKE!! NOW..... IT SMOKES LIKE BOB MARLEY
  4. IronNam
    The PCV shouldn't have a breather, but the hole in the front can.
    i need a pic of the setup.
  5. Dux_Trucks
    campbell CA
  6. Dux_Trucks
    campbell CA
    If you look close you can see all of the oil that I couldn't clean up
  7. IronNam
    that's weird :/ That's how most setups i see, look like.
  8. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    What does the sparkplugs look like?
    Sorry to say but, the only known reason for that much oil/crankcase pressure is blowby...
  9. IronNam
    is the PCV valve upsidedown/backwards?
  10. Dux_Trucks
    campbell CA
    That's what I am saying .... I don't get it I am kind of scared it might go up in flames
  11. Dux_Trucks
    campbell CA
    iI hate to say it too but yea blow by is what I am thinking .....
    but when I pick it up it was more then fine ... I drove the truck .... Fux maybe the ring gap lined up....
  12. thundering02
    thundering02 Addict
    Fenton 63026
    Compression / leak down test would be the fastest answer here. You can rent the testers from the local auto stores usually. (autozone/oreilly/napa/etc.)
  13. Dux_Trucks
    campbell CA
    Yeah I have one .......
    But I'm almost to the point that I don't want to know...... :(
    It was fine when I bought it ...... and when I put it in my truck bob lite one up under the hood
  14. Dux_Trucks
    campbell CA
    Anyone else know of anything ???
    Just askin
  15. B.Y.E.
    B.Y.E. Toyotaholic
    1982 2wd Hilux
    Try this out and tell us if it works... The claims make me skeptical but, also curious!
    En-Valve, The SMART PCV Valve.
  16. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    Its blow by. That valve does look interesting.
  17. broknbonz
    broknbonz Newbie
    Middle Tennessee
    85 xcab
    whats the latest on this, what did you find?
    when i installed my weber i had to clean the carbon from the intake port where the pcv hose connects before installing the supplied plate. it was completely blocked off with carbon/soot
