Hi guys. I'm a newbie with a 93 2WD 22re standard cab, Nummi-built. I am about to retrofit power steering and do some suspension work (new shocks, balljoints, idler arm). I need to remove the rubber splash curtains that go from the inner fender wells to the frame. The curtains are held to the fender well by small button clips that pop out, no problem there, but the lower edge is fastened to the frame member with a larger round plastic clip that doesn't seem to want to pop out. Anyone done this before? Thanks in advance, Cheers, Paul
