spindle vs LCA
Discussion in 'Suspension/Chassis' started by HI_state_toyz, Mar 17, 2015.
  1. HI_state_toyz
    HI_state_toyz Member
    Oahu Hawaii
    89 single cab pick up
    Just looking for info from u guys/ladies wuts better
    I know the spindles cant run the stock 14s. Dont know much the 2. Any info will be helpful thanks :waytogo::waytogo:
  2. 93TILinfinity
    93TILinfinity Veteran
    Lake Elsinore, CA
    1993 Toyota pickup 2wd 4cyl 5speed cab and a half standard bed
    If you search this, the question is answered detailed. But briefly from my understanding, spindles maintain the geometry as if it were stock. That's what I went with. I ran the stock steelies with very little rubbing issues due to the bulky tires. When I went lower, I had to change out the stocks. Lca gives you 3 inches and spindles give you 2 inches and they can be used together
  3. WeGetOurs
    WeGetOurs Member
    Louisiana
    90 st cab 22r
    Just installed 2" drop spindles and I have no problem running 14" stock wheels
  4. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    Yes you can run spindles on 14's. It's been confirmed lol.
  5. HI_state_toyz
    Oahu Hawaii
    Thank you all
